Author Topic: brake pads?  (Read 10191 times)
Offline surajp
brake pads?
« on: 10 September 2003, 16:00 »
hi - anyone got any pearls of wisdom regarding brake pads? My standard pads (1.8T) are due for a change, i would like to upgrade but without having to change disks etc. any ideas of what to go for? ???
Offline Rally_Chris
Re:brake pads?
« Reply #1 on: 10 September 2003, 18:28 »
Common opinion seems to be that Pagid offer the best performance brake pads for use on a Mk4 Golf, but they wear more quickly and produce more dust than standard pads >:(
A good option would be EBC Greenstuff, as they are a little softer than standard pads to give increased performance and they are said to produce significantly less dust than standard pads. These are what I will be fitting to my 1.8T soon as I can't be doing with cleaning those damned montreal 2 alloys!
http://www.golfmk4.co.uk
Mk4 Cruise Control Installation Expert
Offline surajp
Re:brake pads?
« Reply #2 on: 11 September 2003, 12:53 »
Cheers I think I'll give the green stuff ago, the missus thinks i spend enough time cleaning the car anyway! :)
golfvr6
Re:brake pads?
« Reply #3 on: 11 September 2003, 16:09 »
Whats the prices like on the green stuff? is it any good?
Offline jv
  • Administrator
Re:brake pads?
« Reply #4 on: 11 September 2003, 16:49 »
Just got some greenstuff pads fitted on my mk2. I have had them before and never noticed any great performance change but the reduction in brake dust is unbelievable! Cost me a bit under 40 quid for the front set I think.
jv
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
golfvr6
Re:brake pads?
« Reply #5 on: 11 September 2003, 17:04 »
40 bar a lot for some brake pads  >:(
Offline Rally_Chris
Re:brake pads?
« Reply #6 on: 11 September 2003, 19:03 »
It'll be even more for a 1.8T !!
looks like about ?50-60 for a set of front pads for my 2000 GTI-T
golfvr6
Re:brake pads?
« Reply #7 on: 11 September 2003, 19:50 »
Hope you don't need to do the discs at the same time as well  ;)
Offline Nimrod
Re:brake pads?
« Reply #8 on: 15 September 2003, 22:58 »
The standard brakes are so infuriating for dust, I'm out there every week or so scrubbing my alloys otherwise the dust buildup acts like it's been spot-welded on and is a b*tch to get off!  Does anyone have any suggestion for a good cleaner that will cut through the buildup effortlessly?
Offline surajp
Re:brake pads?
« Reply #9 on: 16 September 2003, 10:46 »
Firstly on the brake pad front found that front pads for 1.8T 1999> FR ?62 & RR ?32 from
www.hyperformancedirect.co.uk
they have said they will match or better if a lower price is found.
Secondly, tried turtle wax alloy wheel cleaner and still ended up scrubbing like a b!?@h. so give that one a miss.
