Golf mk4
Wazzzer
1.8t 150 TIP bore size
Topic: 1.8t 150 TIP bore size (Read 1201 times)
Dan_GTi8v
28 May 2011, 20:30 »
Does anyone know the outter diameter of the turbo inlet on the 150bhp 1.8t? Need to get a reducer to complete my cold air relocation but dont wanna have to take it all off just to measure it and put it back on again, just o have to take it all off again a couple days later
Build thread
http://www.golfgtiforum.co.uk/index.php?topic=167291.0
Big Tone
Re: 1.8t 150 TIP bore size
28 May 2011, 22:27 »
You refer to bore in the title, but the outer dia in the thread.
Think bore is 76mm, but double check its a two min job.
Dont know about the outer dia, guess 84mm if the wall thickness is 3mm.
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install, New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Dan_GTi8v
29 May 2011, 16:32 »
its still called a bore size though isnt it? I thought OBD was outter bore diammeter, apologies if it isnt
If its quick job I'll check it out on Tuesday, assumed from its location it would be a pain in the arse. Cheers
Build thread
Big Tone
29 May 2011, 17:09 »
Ive alway know the bore as the inner dia,
OBD= On Board Diagnostic?
Easy job, just undo the tip jubilee and get a rule in there.
Dan_GTi8v
29 May 2011, 18:56 »
ah no sorry I need the size of the inlet as it goes into the turbo from the metal part not where the silicone piece joins onto it
The end of the metal part in this pic where it would bolt to the turbo
Last Edit: 29 May 2011, 20:08 by Dan_GTi8v
Build thread
Big Tone
30 May 2011, 08:59 »
Sorry bud, now I see, don't know that one off the to of my head, still an easy job pal.
Dan_GTi8v
Reply #6 on:
30 May 2011, 15:51 »
OK I'll try and get it off tomorrow, cheers
Build thread
Golf mk4
Wazzzer
