Author Topic: Car back after failed MOT  (Read 2081 times)
Offline the_stink
  • A3 140 TDI
« on: 28 May 2011, 17:51 »
Just got home from work and read through all the things they said had failed and just went out to the car, now one thing they mention is a weird whirring noise which has all of  a sudden developed and also the batt light is also now on?
Just seems a bit convenient that I take it to the garage and all of a sudden there are problems that need to be sorted that werent happening about 9 hours ago
and it also looks like they didnt use a seat cover as well! driver seat is filthy
Offline Thom89
  • Looking for an "Icebreaker"
Re: Car back after failed MOT
« Reply #1 on: 28 May 2011, 18:01 »
Check your alternator belt Joe, its likely its either that, or the alternator itself giving up the ghost...
Thom
Offline matping
  • MK1 20vT MK5 GTI T
« Reply #2 on: 28 May 2011, 19:50 »
deffo alternator whining !! when its running spray some wd40 into it   :smiley:
Offline Sam
  • Sam I am
« Reply #3 on: 28 May 2011, 21:59 »
Surely they cant fail for 'a weird wining noise' and yes, alternator issues (thinking this without reading the rest)  :lipsrsealed:
Offline the_stink
  • A3 140 TDI
« Reply #4 on: 28 May 2011, 23:14 »
na that didnt fail but it was noted down 'to check' etc, going to spk to them on tues and book it in
Offline cняis
« Reply #5 on: 28 May 2011, 23:38 »
adjusting the belt tension takes about 2 seconds  :smiley:
Offline Guy
« Reply #6 on: 29 May 2011, 00:58 »
replacing the alternator shouldn't* take you too long either, if it is that.. don't book it in for that
*unless its a mk1 with a fcuked alternator bolt  :grin:
Offline Sam
  • Sam I am
« Reply #7 on: 29 May 2011, 01:12 »
As soon as you loosen the main bolt after the tensioner from the altanator you arent sure if its removing itself or you are.  :grin:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #8 on: 29 May 2011, 09:26 »
Before you start thinking about getting a new alternator, check the brushes. They may be worn.  This is why the red battery warning light comes on.  Whirring noise - as said - could be the belt or a worn bearing.   Brushes-belt-WD40.
Offline the_stink
  • A3 140 TDI
« Reply #9 on: 29 May 2011, 12:44 »
Cheers for all the replies guys, helpful as ever!! So if the batt light is on could be the alt thats causing it, ill have a look at the belt tension try some WD40 but in work till 5 today  :angry:
