Author Topic: Rear Carriers aghhhh  (Read 2159 times)
Offline S4twiggy
« on: 28 May 2011, 09:43 »
this golf is stressfull lol how do i get the rear carriers off lads, thought it was torx bolts but none of mine fit. is it a certain size as 10 doesnt fit and 12 is too big. do they make an 11size torx bit??
or is there another way at getting them off
Audi S4(B5) BBS CH's, Eibach pro street coilovers, B5 RS4 brakes(360mm), MRC remap 320hp 370lb ft. Fully Certified Detailer
Offline S4twiggy
Re: Rear Carriers aghhhh
« Reply #1 on: 28 May 2011, 10:01 »
if all else fails and you dont have a 14mm torx bit then stilsons will get them out lads  :grin:
Offline kalpsn2000
« Reply #2 on: 31 May 2011, 15:56 »
You will actually need a 14mm spline bit. Although when I tried to remove mine a few weeks ago the bolts were too tight for me to get off :sad:
New: White Mk7.5 GTI (Standard...for now :smiley:)
Gone but not forgotten:
Diamond Black 2007 (56) Golf GTI 3Dr DSG ¦ 18" Monza II's ¦ Cruise control ¦ MFSW with Paddles ¦ Highline ¦ Rear parking sensors ¦ RCD500 to RNS510 C LED to Kenwood DNX521DAB ¦ Lowered on H&R springs ¦ R32 Rear bumper ¦ BCS Powervalve Sports R32 style TBE ¦ LED Rear Lights ¦ PDT Stage 1 ¦ NQSBBK ¦ 12mm Spacers ¦
Offline maxitrol
« Reply #3 on: 02 June 2011, 08:11 »
its a m14 spline socket you neen to remove the back carriers,i had a big hollow bar on the end of the ratchet to undo mine
Offline kalpsn2000
« Reply #4 on: 03 June 2011, 01:14 »
How did you manage to fit that under the arch?
Offline S4twiggy
« Reply #5 on: 03 June 2011, 08:28 »
its not that they were too tight its i didnt have the right bolt lol
so its 14mm spline i need to get for next time. cheers lads
Offline maxitrol
« Reply #6 on: 05 June 2011, 21:47 »
am lucky as i have the use of a 2 post ramp i am a tyre and exhaust fitter
