Author Topic: Oil pressure beeper when pushing it..  (Read 737 times)
Offline jamie_pyrite
« on: 27 May 2011, 11:54 »
1996 mk3 tdi 1.9 1Z - 178k on the clock.
If I push the car in say 3rd gear and get up past 3k towards 4k the oil pressure beeper comes on! As soon as I change gear or drop my revs down, it goes straight off.
What would cause this? It's never ever happened at any other time than pushing the car..
Offline Khare
  • The bear that khares
Re: Oil pressure beeper when pushing it..
« Reply #1 on: 27 May 2011, 12:02 »
There are two oil pressure senders, one for lower RPM and one for higher RPM. If the higher RPM one is buzzing then you've either got a faulty pressure sender or an oil pressure problem.
« Reply #2 on: 27 May 2011, 16:26 »
Ahh.. I didn't know this! Do you happen to know at what RPM it switches to the higher sensor?
Offline Khare
« Reply #3 on: 27 May 2011, 19:40 »
I think it's a 2500rpm or thereabouts  :smiley:
