Author Topic: Even more advice on mk2 8v 91'  (Read 2339 times)
Offline mk28vfreak
  • VWVWVW
« on: 10 September 2003, 12:51 »
Hi Guys and Gals,
Further to my previous posts i have had lots of work done on my gti and have managed to fix most problems, all but one.  I still cant seem to stop it Misfiring/Backfiring.  It only seems to happen when changing down through the gears when travelling reasonably fast.
So far i have had done/ replaced
New Clutch
New Cambelt + Tensioner
New Cam followers
Full Service with all Filters/Leads replaced
Ignition Timing checked
No Vacuum Leaks
Checked all Hoses.
The car run like a dream, apart from this one niggling problem.
Please, please, please
Any Ideas????????????
golfvr6
Re:Even more advice on mk2 8v 91'
« Reply #1 on: 11 September 2003, 15:58 »
Check the fuel mixture.
Offline mk28vfreak
  • VWVWVW
« Reply #2 on: 12 September 2003, 14:59 »
Thanks for the post,
Had the mixture checked, was running a little lean, but adjustments seem to have made no difference.
Offline Slim Shady
  • Thrash her like a ginger step child
« Reply #3 on: 12 September 2003, 15:45 »
f**ked valves?
if the timing and the mixture is OK -it's time to inspect your top end
golfvr6
« Reply #4 on: 12 September 2003, 15:52 »
Compression test maybe?
