Author Topic: Cambelt & waterpump tips - DONE!  (Read 2137 times)
Offline Big Tone
« on: 26 May 2011, 00:28 »
Going to have to do this on Friday
must get it done.
Have ordered a cambelt kit,tensioner and waterpump.
Any tips?
« Last Edit: 27 May 2011, 18:18 by Big Tone »
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Granta Gti
Re: Cambelt & waterpump tips
« Reply #1 on: 26 May 2011, 07:15 »
Are you doing it yourself?
Offline 1 gti
« Reply #2 on: 26 May 2011, 08:23 »
Also the hydraulic tensioner damper I think it's called. It's not part of the kit which is stupid. It's about £100 from the dealers. Quite a few people forget to do this.
Offline Big Tone
« Reply #3 on: 26 May 2011, 08:46 »
Yup,
Offline Big Tone
« Reply #4 on: 26 May 2011, 08:53 »
Yup, do you know of any other how to.s? Sren the one on ukmkivs but thats it.
Offline T_J_G
« Reply #5 on: 26 May 2011, 08:56 »
It's not a straight forward job so factor a days work if you have the right parts (check and check again...) You may need two jacks, one to raise the car and the other to raise the engine. I helped do mine and to be honest wouldn't want t do it again. Getting the belt on can be a right pain.
I know labour is expensive but it'll offer some form of comeback, if you DIY then your belt snaps or the timing is out you've got an even larger bill!
EDIT: Remember you'll need coolant, and while it's all drained I'd put a new thermostat in, as when mine went it cooked the stat, so it overheated AFTER the pump change. My thermostat was only 8 months old as well (VW part) . Should only be about an extra £10 and 10 mins work as you'll have the coolant drained.
« Last Edit: 26 May 2011, 08:58 by T_J_G »
Offline Big Tone
« Reply #6 on: 26 May 2011, 09:34 »
Nice one, I know its a pain but I have no choice, plus once I have done it......right?
Got two jacks and stands and all the tools listed ib the "how to" just wanted to double check.
Anyway, hope its fine tomorrow :lipsrsealed:
Offline T_J_G
« Reply #7 on: 26 May 2011, 09:53 »
you got a thermostat to pop in?
You want to get cracking tomorrow as it's a bank holiday weekend and all parts/tool places will be shut Monday!
Wish you the best of luck and hope it all goes according to plan!
Offline Big Tone
« Reply #8 on: 26 May 2011, 09:55 »
Cheers, fingers crossed!
Cambelt is not due for another 10k!
Oh, and I do have a new stat, even though the existing is only 6 months old
« Last Edit: 26 May 2011, 09:57 by Big Tone »
Offline T_J_G
« Reply #9 on: 26 May 2011, 09:59 »
Still worth changing though as my genuine one that has nly been in 8 months didn't make it through the over heating!
Have you diagnosed it as the pump? If you take off the thermostat housing and put your fingers in and down in the coolsnt channel to the left you can feel the pump impeller. If it spins freely it's knackered!
