Author Topic: more fault codes , can someone help me please  (Read 884 times)
Offline spudboy6
  • Just like a golf ......
so my codes are
00525 -G39 - 02 sensor , i know to change the lamba on this
00519- intake manifold pressure sensor -G71 signal too low ? what do i do
00625- vehicle speed sensor signal not plausable ? what do i do
00588- airbag igniter drivers side N95 ressistance too high
im mainly worried about this speed signal sensor and manifold pressure sensopr , if anyone could help me please i would be ever so thankfull ,
Offline trog_nfs
Re: more fault codes , can someone help me please
« Reply #1 on: 25 May 2011, 13:37 »
MAP sensor is with the ECU, there's a piece of vacuum pipe going to it that perishes and leaks. Have a check see if there's a leak.
Offline spudboy6
« Reply #2 on: 25 May 2011, 13:49 »
Do these vaccum pipes actually join to the ecu ? And is map sensor on the 1.4 AEX on the drivers side if the manifold with a 4wire plug ?
Thanks
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 26 May 2011, 16:22 »
AEX is on the manifold, its a small things that bolts directly to it,  i think it is 4 pin from memory, not many other 4 pin things bolted to the manifold anyway  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
