Author Topic: how to remove the steering wheel  (Read 1421 times)
Offline gazman1011
  • if your not first, your last!
« on: 24 May 2011, 17:42 »
hi all, just woundered how to remove the steering wheel so i can replace the mfa and indicator stalks
thanks
Offline The Mighty Elvi
  • I'm better than you today.
Re: how to remove the steering wheel
« Reply #1 on: 24 May 2011, 17:46 »
Pop of the horn cover in the middle. Unclip the horn electrical wires.  Whack on a socket and extention bar and release the nut.
Simple as.
The steering column is a splined shaft.  The steering wheel has a splined hole - for want of a better word - it just slips on and off.
make sure to mark the splines so that when you reassemble  the wheel is on straight.
Offline Reasty
  • Alpine white valver.
« Reply #2 on: 24 May 2011, 17:46 »
Pull off centre cap, undo big bolt, pull off steering wheel  :rolleyes:
Offline gazman1011
« Reply #3 on: 24 May 2011, 18:12 »
why thanks
