Author Topic: 60mm drop on GL wheels  (Read 2012 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 24 May 2011, 17:12 »
I have just got some 60mm springs, its a low mileage car with good shocks, so i opted for springs only this time,  only it has the standard 6 spoke GL alloys (13/14 inch i forget which one)  Any one know if a 60mm drop is too low for these wheels? its ground clearance im worried about, i couldnt go over a speed bump with a 35mm drop so i worry this might be a bit too low (the mrs uses the car more than me see and i would like to keep the sump in once peice)
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline dom
  • Back in a Mk4
Re: 60mm drop on GL wheels
« Reply #1 on: 24 May 2011, 17:17 »
60mm will be fairly low but i'd say your sump will be safe as long as she doesn't hit speed bumps at 60mph.
Your shocks will fail quickly with 60mm lowering springs though :wink:
Offline murraymint
« Reply #2 on: 24 May 2011, 18:18 »
i fink mine is sat 70mm lower on steels and part from hitting the splitter on everything i've only hit the downpipe a couple times and no sump smashers yet lol
josh
« Reply #3 on: 25 May 2011, 00:00 »
Cannot see your shocks lasting.  :smiley:
Offline Rmachines
« Reply #4 on: 25 May 2011, 15:32 »
They have only done 67k miles, so hopefully they have a bit of life in them, its no big deal, a whole kit is £100ish.  Saying that i might sell these springs and change for a 35mm kit, I know they sit nicely at 35 and remain practical.    My passat is sat at 60/40 on stock shocks and has done for the past 6 years and 40k miles.  And shocks are spot on!  :wink:
Offline Bellend
« Reply #5 on: 25 May 2011, 17:12 »
Done 120mm on 14" GL wheels. You will be fine.
Where all my moneys went.
Offline tweed
« Reply #6 on: 25 May 2011, 17:17 »
You can get coilovers for £150!
Your shocks wont last long and you will have buy new ones and refit everything twice.
How much are four shocks?  :grin:
Offline Rmachines
« Reply #7 on: 25 May 2011, 19:02 »
I dont want coilovers, had them on my last car and ride was a bit too hard, the car rattled its self to bits,  I work in a garage so refitting twise is no issue if need be, but i dont want to spend any money on it to be honnest, these springs were super cheap,  i dont keep any of my cars long enough to have that problem  :grin:
Offline Bellend
« Reply #8 on: 25 May 2011, 23:45 »
60mm springs are probably going to be harsher then coils.
Offline Rmachines
« Reply #9 on: 26 May 2011, 16:19 »
Thanks for the pics,  I might just be the coilovers i had,  they were awfull, i have driven a renault 5 on the bump stops for 20 miles and it wasnt as hard as my coilovers  :grin:  and im really not joking!
My bro is after my springs now so i might strike a deal and get a full kit, not sure yet.
