Author Topic: Multifunction display fading  (Read 1372 times)
Offline Ashleydwsmith
« on: 24 May 2011, 16:00 »
Hello,
My multifunction display ( if that's what it is called), is fading during the course of the day.
First thing in the morning it is fine and dandy, however when I go back to it later it has faded and I can't see it.
Can the display be replaced on it's own?  Or do you have to replace all the clocks? And then other units as I've been told that it's all part of the immobiliser.
'99 1.8T GTI, indigo blue. Agu.
Offline mcgee9t2
Re: Multifunction display fading
« Reply #1 on: 24 May 2011, 16:24 »
iirc you cant replace the display, have to replace the clocks.
nothing else needs to be replaced, just the clocks. have a look on ukmkivs theres a right up as to what immo clocks you can have.
i think if you have immo 2 you can fit either immo 2 or immo 3 but if you have immo 3 you can only fit immo 3.
Offline gm8
« Reply #2 on: 24 May 2011, 16:29 »
Mine is the same , however you will prob notice it only when its hot. Warm days its barely visible , but first thing in morning , night etc its crystal clear . I have just learned to live with it
Offline andc1
« Reply #3 on: 24 May 2011, 17:58 »
mines the same, i live with mine as when sun is out and cant really see it anyways
