Author Topic: Audi propshaft seal  (Read 1541 times)
Offline AudiA8Quattro
Audi propshaft seal
« on: 24 May 2011, 10:43 »
This question will probably apply to vw's as well as audi's.
I need to replace the front prop seal on the A8, the dealer told me today that if i replace the seal then i also need to replace the flange, as they are matched.
The seal is 17 quid, the flange 180 quid  :shocked:
I've never heard of this before, is this correct?
cheers.
Re: Audi propshaft seal
« Reply #1 on: 24 May 2011, 11:26 »
Seems odd, I cannot see the flange being matched to the seal.
I would clean it up with fine emery paper then fit a new seal.
We do lots of propshaft seals in work and never replace the flange unless badly marked.
« Reply #2 on: 24 May 2011, 11:32 »
Thanks Wayne.
Its what the dealer said Audi advise.
Maybe it is just an advisory then. Matched doesn't seem right.
« Reply #3 on: 24 May 2011, 11:53 »
Thanks Wayne.
I would chance it tbh, £17 for the seal as I said clean the flange and see what happens, if it leaks again then you know your looking at a new flange if not you have saved loads.  :smiley:
« Reply #4 on: 24 May 2011, 11:59 »
Problem is its not a job i want to do twice.
To be honest i'm looking at paying to get it done, i need to get the car up on all 4 corners really.
« Reply #5 on: 24 May 2011, 12:05 »
Fair enough, I still think you will be ok to reuse the old flange.
