Author Topic: sensor on the intercooler  (Read 1440 times)
Offline 20v
« on: 23 May 2011, 20:33 »
as title wot does it actually do why is it there
wot do u do wiv it if fitting an aftermarket fmic
Offline symsymma
  • AGU POWER,drive it like u stole it!!!
Re: sensor on the intercooler
« Reply #1 on: 23 May 2011, 21:16 »
Map sensor.not sure wot it does,mines an agu and dont have one aftermarket i/c should have holes for it if not you can get map sensor tubes with mounting holes for sensor that u fit inline with the i/c pipework.check out the forge website they can supply em.hope all is well in ur neck of the woods mate.hows it all goin? :smiley:
1.8T AGU 203bhp & 233lb/ft Rtech stage 1 custom remap,18"dezentz rims,lowered 40mm shocks n springs,whiteline 24mm adj rear arb,lcr axle bushes,polybushed arb,modified front bumper & valences,depo projector headlights,delocked,wrapped interior&bora gear knob,forge boost & coolant hoses,forge tip,forge 007p,samco vac hoses,simota aeroform cai,saiko michi catch can,deleted pcv system,r32 dogbone,miltek lg bore down pipe & sports cat/non res anni style system.
Offline 20v
« Reply #2 on: 23 May 2011, 21:28 »
top man spouse ill have to get one of those then
did i get the grill off you ?
Offline symsymma
« Reply #3 on: 23 May 2011, 21:31 »
Yea you did mate,all fitted?
Offline 20v
« Reply #4 on: 23 May 2011, 21:38 »
ahh cars actually in bodyshop now havin a full respray
Offline symsymma
« Reply #5 on: 23 May 2011, 21:40 »
Nice wot colour?how much you payin and is it local?
Offline 20v
« Reply #6 on: 23 May 2011, 21:49 »
same colour inigo blue fink its called an 900 yer in  stapleford by hertford
Offline symsymma
« Reply #7 on: 23 May 2011, 21:56 »
Thinking bout gettin sum bits sprayed meself wouldnt mind seeing urs wen its done so i can see the quality of the work.only bout 4 miles from me to stapleford.you goin volkfest at northweald?
Offline 20v
« Reply #8 on: 23 May 2011, 22:06 »
wen is it an yer u got my number still?
Offline symsymma
« Reply #9 on: 23 May 2011, 22:14 »
Sun 19th of june mate,im gettin there early to sign on for q mile.i missed it last year so am eager to go this year.ill pm u my number get in touch if ur up for goin or wen ur cars back init. :smiley:
