Author Topic: Water Temperature  (Read 2256 times)
Offline Helios_Blue_Valver
Water Temperature
« on: 09 September 2003, 22:08 »
just wondering if anyone has had a similar problem. On my way home tonight I noticed the water temp light would flicker off and on for a few seconds then stop again. The temp gauge was reading just below half a gauge (seems to be where it always reads when warmed up) no signs as to it over heating and the coolant level is fine. Dodgy sensor for the light perhaps?
Re:Water Temperature
« Reply #1 on: 10 September 2003, 19:11 »
Got it sorted. feel stupid, wire came lose under the rubber cover on the sensor and was just touching the tab. when the car moved just right it would move away and break contact. thanks anyway
Offline Jimmyrallye
  • 20vt goodness
Re: Water Temperature
« Reply #2 on: 31 May 2012, 23:07 »
Hi im haveing this same problem could some one tell me were this sensor is :(
Offline molegti
« Reply #3 on: 01 June 2012, 07:26 »
The sensor is in the middle of the header tank
Offline Jimmyrallye
  • 20vt goodness
« Reply #4 on: 01 June 2012, 12:54 »
Cool thankyou so its the sensor on the water bottle in the top right hand corner of engine ? :)
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #5 on: 01 June 2012, 18:33 »
Dash light will also flash if the level is a little low...
Thom
Offline JC
  • Back in the North.
« Reply #6 on: 03 June 2012, 18:52 »
Thom
i noticed this, just after my footwell became a foot spa  :laugh: :grin:
