Author Topic: Shallow Sumpage?  (Read 2115 times)
Offline thatwillis
Re: Shallow Sumpage?
« Reply #10 on: 23 May 2011, 20:15 »
it will catch fire if you weld it, with the oil resdiue i would have thought...
if you do it please video it
Brake cleaner will get rid of all the oil  :smiley:
Ill see if i can do a vid.
Offline thatwillis
« Reply #11 on: 23 May 2011, 20:23 »
hahaha Hmm yes that would be a royal pain in the arse and yeah a fire....  :laugh:
Offline houston
« Reply #12 on: 24 May 2011, 00:29 »
lift the engine?
lift the engine?
How hard is it to do the engine spacers? I'm Guessing you need to do exactly that! With the engine on a hoist and change the spacers. But that can be left for another time once the sump is fixed.
Oh I was expecting people to rate the shallow sumps. I was quoted 92quid + vat at tps! Which is almost the same price as a shallow one!
Does anyone have a trade name i can use to get some discount =D
Welding up a sump? Worth doing any obvious problems with this? Someone at work could weld it up for me i think.
Thanks
James
no need for a hoist, just use a jack on the sump but with a bit wood to spread the load.
arent the sumps aluminium? need to get them very hot for a weld to take if they are
Offline dantheman6554
« Reply #13 on: 24 May 2011, 08:44 »
Hmmm welding sump on a car,  not good!   did that once on my corsa , caught fire and blew the rocker cover off due to the pressure!  not good !
I had my old sump Tigged, didnt do a bad job but really its never going to be strong enough against hitting a speed bump at 20 mph!
Dan
Good Old Gt Tdi 115!
Offline thatwillis
« Reply #14 on: 24 May 2011, 10:05 »
Yeah its ali so fun to weld but to bad if the welder knoes what there doing. Yeah would be tigged. In a machine shop at the momment so shouldnt be to hard to find some one to weld it.
Ill have a look into engine spacers. That hard to fit yourself?
« Reply #15 on: 24 May 2011, 10:22 »
Wish i had a video of it, i was doing an oil change on the car and noticed a hole in the sump, draiend out what i though was all the oil, stupidly started welding, the gas must have pressurized in the engine then when i ignited the torch, boom!!
Burnt all the sound proofing on the inside of the bonnet!   Lesson Learnt!
Dan  :smiley:
Offline GolfGTI8v
« Reply #16 on: 24 May 2011, 11:03 »
I got a gwerks "shallow" sump on my agu,  Great product in my opinion, fitted really well and has a steel base to protect from any future impacts, came with a new modified pick up pipe. i had to get a different oil return from them as well as it sits at a different angle,  the engine still takes the same amount of oil as standard sump!
Thumbs up for it  :smiley:
