Author Topic: Cambelt and Crankshaft Bolt  (Read 4554 times)
Offline mk2_1.8
« on: 18 May 2003, 12:57 »
Golf 1.8 1990 8v
I will be changing my Cambelt Next weekend. Had a quick look at it today and it seems the crank pulley needs to be removed to remove the bottom cover. I noticed the Crankshaft bolt looks like a "Star" type head. Can anyone tell me what size this is or is there a special tool? Also, is there an easy way to loosen it? From previous experience I know they can be a pain.
Any other tips on changing the cambelt appreciated.
p.s. the car has power steering.
Thanks
« Last Edit: 01 January 1970, 01:00 by 1055631600 »
Offline ddubya
Re: Cambelt and Crankshaft Bolt
« Reply #1 on: 19 May 2003, 02:34 »
i changed cambelt on my 1990 8valve with p/s,the bottom pulley came off just by undoing the 4 allen key bolts, did not have to undo the big star bolt. i had an 1988 8 valver before and had to undo a big nut ie 19mm,this would not undo even at work with a nut runner so had to take it to a vw specialist and they could not undo it either they had to cut it off with oxy- ascetaline. i got a second hand pulley from smashing vws in leeds, hope yours is the same as my current gti peice of piss    ;)
Offline Bdub
Re:Cambelt and Crankshaft Bolt
« Reply #2 on: 24 June 2003, 11:56 »
Just done mine on an 89 8v - you definately don't need to undo the crank bolt, just the 4 allen head bolts on the vibration damper pulley - you might need a puller to get it off though when the bolts are removed - it was bloody tight on the shaft.
Any more probs reply and I will advise.
