Author Topic: heater only works on stage 3  (Read 1538 times)
Offline 17gti
« on: 30 March 2005, 23:16 »
hi my heater works and i get heat now but im not getting heat on 1 and 2 stages on the heater i ownly get the really fast blower thats number 3 i was wondering what it couled be and another thing is that what does a 99 realy do from a mk3 to a mk2 i was told its to do with the wipers or somethink and were to i put the 99 in my mk2 1.8 8v 1990  thanks
Offline LPG'd Oakie
  • Haha...I own one now!!!...And it works...ish
Re: heater only works on stage 3
« Reply #1 on: 31 March 2005, 00:18 »
Sounds like the relay, which I am told is no major drama to fix. Check ebay, theres always some for sale as it is a very common problem.
Offline 17gti
« Reply #2 on: 31 March 2005, 00:47 »
were is the relay for the heater and what number is it
Offline GTI EDITION (aka LTD)
« Reply #3 on: 31 March 2005, 01:02 »
I THINK YOUR PROBLEM IS THE DIODE ON THE RESISTOR PACK WHICH IS FOUND ATTACHED TO THE FAN HOUSING. I HAVE REPLACED QUITE A FEW OVER THE YEARS .YOU CAN EITHER REPLACE THE COMPLETE RESISTOR  OR SOLDER ON A NEW DIODE  ( MAPLINS OR AN ELECTRICAL SHOP LIKE THEM SHOULD BE ABLE TO MATCH ONE UP )  TO REMOVE THE FAN TURN IT ANTI-CLOCKWISE AFTER RELEASING THE LOCKING TAB . CHECK FAN FOR FREE MOVEMENT THEY DO HAVE A HABIT OF SEIZING UP  :smiley:
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
Offline Gambit
« Reply #4 on: 01 April 2005, 10:48 »
yep you need a new heater resistor pack. they cost about £20 from German Swedish French
but the reason these burn out is becuase water has got into the fan itself and tightened it up. so if you just replace the resistor it will burn out again sometime down the line
so when you have the motor out of the car. soak it in WD40 and this will help free it up a good bit
