Author Topic: Mk3 Misfire.  (Read 1152 times)
Offline Bambam
Mk3 Misfire.
« on: 22 May 2011, 16:03 »
G'day folks.
I have a '98 8v Gti with 114,000 miles. It's nothing special, a bit scabby in places but it does the job just fine.
A few weeks ago I noticed a slight misfire and so serviced it with new plugs, filters and fluids. I couldn't get the correct HT leads so left that for later (it's a late Mk3 and I often find the 'correct' parts are not that at all). After servicing the misfire seemed to be worse so I tracked down the leads and fitted them. No joy, in fact the problem is more obvious, so I'm wondering where to go next?
I'm okay with swopping parts myself and simple diagnosis but without knowing what to change I'm stuck. Injector? Fuel pump? Something on the ignition circuit?
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Mk3 Misfire.
« Reply #1 on: 23 May 2011, 16:38 »
Coil pack causing a weak spark,  it will suddenly give up on you so make it your next item to check.
Very common,  I keep on in my glove box now  :grin:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Bambam
Re: Mk3 Misfire.
« Reply #2 on: 23 May 2011, 20:48 »
I was about to swop that but read a reply to a post I'd made on Pistonheads (same question). Someone said it sounded like the fuel pump relay which was known to cause the symptoms I described before leading to the engine cutting out as it stopped the fuel pump at random.
Guess what happened last night?
Without warning, 40mph, the engine died. Coasted to the verge, turned the key, engine started, drove off.
 :huh:
