Author Topic: mk3 trouble with electric windows??  (Read 913 times)
Offline mattyb12345
« on: 22 May 2011, 15:14 »
i just came out to my car and both my drivers side and passenger side windows were down i put them back up only to find 10 minutes later they went down again.. but now i cant get them back up. HELP!?  thanks matt.
mattyb
Offline DubFan
Re: mk3 trouble with electric windows??
« Reply #1 on: 22 May 2011, 15:29 »
I had the same problem with a rear electric window on my old Mk3 16v.
I didn't realise it didn't work at all when I bought the car, when I realised the fault I got the garage to "fix" it. Then every so often the window would wind down of it's own accord.
Took it back to the garage who told me that the window motor had been disconnected before, so their "fix" was to reconnect it. So the fault had existed before but the previous owner had disconnected the motor instead of trying to fix it. I got them to disconnect it again as I wasn't bothered about the rear windows and I sold the car a few months later anyway.
So I haven't got a good solution to that problem, but if you're not bothered about windows (  :undecided: ) then you could just disconnect them.
It might be related to a knackered door wiring loom or a dodgy switch.
You could try replacing the switch first. Also open the door and pull back the black rubber boot that covers the wiring loom between the car body and door. See if any of the wires look broken.
Offline mattyb12345
« Reply #2 on: 22 May 2011, 15:39 »
yea ive pulled back the rubber coating thing in my door panel couldnt see anything wrong with it. mines a 3 door so i need my 2 front windows really its summer coming up and i love my drive thru's lol :P.. i just managed to get them up again. no doubt they will be down in 10 minutes again
mattyb
Offline dan_apps
  • too low for british roads!
« Reply #3 on: 22 May 2011, 19:37 »
could be the motor itself as apparently they are shockingly crap, mine has recently gone on o/s front and i pulled the motor out and wedged the window up with a piece of wood. not ideal but i will sort shortly.
« Reply #4 on: 22 May 2011, 19:53 »
Could also be a fault with the drivers door lock.
Offline mattyb12345
« Reply #5 on: 23 May 2011, 11:05 »
yea i think your right wayne i cant open my passenger door now either
mattyb
Offline javalin
« Reply #6 on: 23 May 2011, 11:07 »
what wayne said.  There are linkages in the drivers door lock to activate the all-up or all-down functions on the windows.  If they break/get stuck/whatever then you can get what you have.
J
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
