Author Topic: A discussion about fuel injection systems  (Read 655 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 22 May 2011, 12:28 »
I have a good understanding of modern SEFI systems but not so much about the old Mechanical and single point EFI.  Have a few questions..
First off,  obviously with multi point, the fuel cuts off when the throttle position sensor / Map sensor senses the throttle is close on deceleration, so no fuel is used when going down a hill for example..
Is this the case for single point?  The reason i ask is theres no reason why single point cant cut off, but all my single point engines past and present have backfired on over run,  why  is there unburnt fuel on decleration?
Seccond question,  Does Mechanical injection cut off on overun?  Bosch K jetronic for eg on the KR engines...   Its a mechanical metering unit, does it totally cut fuel on overun ?  Or does it drop to base idle settings?   Never looked into Kjet much.  ... again these also backfire on decel
Freel free to post other questions here too...  Im going through a "want to learn about Fuel injection phase)  :grin:
« Last Edit: 22 May 2011, 13:31 by Rmachines »
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline javalin
Re: A discussion about fuel injection systems
« Reply #1 on: 22 May 2011, 16:10 »
as far as I know the single point injection and multipoint injection works the same way, bar maybe some older cars...?  Its all about how the ECU was coded.
>Second question,  Does Mechanical injection cut off on overun?
not sure, but suspect it just reduces as no throttle applied.  was there mechanical petrol injection, thought that was just diesels?
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline Rmachines
« Reply #2 on: 23 May 2011, 11:03 »
The early ford xr3is and mk1 and 2 golf gti used bosch k jetronic which meters fuel using a flap that lifts up and down with air flow, there is no electronics although kl jetronic had electronic ignition i guess its not sequential so all four injectors must spray at once ?
