Author Topic: Air flow meter mod?  (Read 2351 times)
Offline Andy!
  • VR6
Air flow meter mod?
« on: 22 May 2011, 11:23 »
Somewhere on here there is a thread detailing an adjustment to the internals of a digi air flow meter.
I'm having a mare trying to find it, can anyone link me?
Offline russ-vdub
  • Once a Dub, Always a Dub
Re: Air flow meter mod?
« Reply #1 on: 25 May 2011, 08:44 »
What does this achieve? Just curious?
Offline DOA
« Reply #2 on: 25 May 2011, 12:54 »
Offline russ-vdub
« Reply #3 on: 25 May 2011, 17:00 »
Quote
Reducing AFS Spring Tension
To reduce the spring tension, first remove the black plastic cover on the air flow sensor by cutting up through the silicone sealer with a sharp blade. You will see, among other things, a black gear-wheel on top of what looks like a clock spring. A wire clip engages a tooth on the gear-wheel and is held in place by a 7 mm screw.
Scribe a permanent mark on the gear-wheel at the tooth where the wire clip engages (This is so you can go back to the stock setting if need be).
This is the tricky bit: Get a good grip on the gear wheel with your fingers. Loosen the 7 mm screw and wire clip assembly. Don't drop anything, and whatever you do, don't let go of that spring, or you may never get the car to run correctly again!
Now, carefully unwind the gear-wheel 3 teeth counter-clockwise. This is no more than 8 or 9 mm, so be careful. Reset the wire clip three teeth to the loose side of stock. Tighten down the 7 mm screw, replace the black cover with a thin bead of silicone sealer and you're done.
I tried one, three, and five teeth... one didn't seem to do much, five actually reduced power. Three was just right. Stay with three teeth because the down side of too rich a mixture will be increased emissions, and possible damage to the O2 sensor and/or catalytic converter. YMMV.
I can report that this tweak helps solves some perceived Digifant driveability problems (assuming all else is in order). Hesitation is reduced, throttle response is crisper, and there is mildly quicker acceleration in the lower gears due to increased torque. Gas mileage does not appear to suffer much.
Offline Andy!
  • VR6
« Reply #4 on: 25 May 2011, 20:24 »
Try looking at http://www.members.tripod.com/~fuelie/performance.htm
Thanks to all and quoted in particular, some interesting reading.
I've decided to leave it alone.
Offline russ-vdub
« Reply #5 on: 25 May 2011, 20:34 »
Yeh and i need a new airbox lol!
Offline DOA
« Reply #6 on: 26 May 2011, 12:37 »
Possibly for the best  :grin: :wink:. BTW, are you based in Garstang, Im sure I know your car?
Offline Andy!
  • VR6
« Reply #7 on: 26 May 2011, 19:05 »
I bought it from a guy who works in Garstang. It was neglected and a bit tatty but is slowly getting to be a nice little motor. Has to be some advantage to working for ecp!
