Author Topic: brake pipe lines.  (Read 838 times)
Offline sharki786
  • GOT BOOST??
brake pipe lines.
« on: 21 May 2011, 17:36 »
need to do my brake pipe lines. could i get the complete set from TPS? if so, how much would it cost me?
thank you
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mhoney
Re: brake pipe lines.
« Reply #1 on: 21 May 2011, 19:09 »
Hi it would be easier and cheaper to make your own brake lines up check out www.frost.co.uk you can buy a kit with everything you need
hope this helps matt
« Reply #2 on: 21 May 2011, 21:44 »
As above, make your own, easy enough to sort.
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 21 May 2011, 21:54 »
Believe me its a LOT easier to make your own than get pre-made as they weave in and out of all sorts of things, I quite enjoy making up brake pipes  :smiley:  They are fitted to the car before the rear axle and other parts in the factory so refitting the complete pipes is generally not done.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
