Author Topic: headlight swap  (Read 1073 times)
Offline stainesy
headlight swap
« on: 21 May 2011, 15:52 »
this has probly been covered on here loads of times so sorry peeps.
i have the gti 2 chamber headlights on my car as standerd but i prefer the look of the old single chamber headlights.
can i just swap them over for the single chamber ones or do they have diferant plugs?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: headlight swap
« Reply #1 on: 21 May 2011, 16:03 »
Different plugs but can be swapped very easily.
Offline stainesy
Re: headlight swap
« Reply #2 on: 21 May 2011, 16:06 »
right so need to get myself a couple of single chamber plugs from a standered golf then?
Offline dom
  • Back in a Mk4
Re: headlight swap
« Reply #3 on: 21 May 2011, 16:19 »
Plugs may be the same, some are square some are round it depends on the year of the car. You can usually tell by the shape of your side repeaters.
Best bet is to check the shape of your plug and make sure you buy a set of single chamber lights with the same shape plug, no need to mess around getting different plugs if there is no need.
Re: headlight swap
« Reply #4 on: 21 May 2011, 21:46 »
As Dom said, you can get both types of plugs on single chamber headlamps.
Offline dom
  • Back in a Mk4
Re: headlight swap
« Reply #5 on: 21 May 2011, 23:32 »
That's a much better way of saying what I was trying to say :grin:
Offline will_jb
Re: headlight swap
« Reply #6 on: 23 May 2011, 10:47 »
When i changed from the single chamber to the gti dual's, i just swapped straight over using same power connector.
Hope this helps  :smiley:
Offline AndyMk3
Re: headlight swap
« Reply #7 on: 23 May 2011, 17:23 »
Got a set of single chamber with adapters available matey make me an offer
