Author Topic: 02y to 02a conversion  (Read 1212 times)
Offline mk2bal
« on: 21 May 2011, 11:27 »
im changing my fooked 02y for an 02a next weekend.. im not sure of the code on the box, but i can find out.. im after a vr6 clutch, will it defo fit the 02a without knowing the code? im trying to order up all necessary seals in advance, but without seeing the box etc i dont know what i need!! is there an outer input shaft seal on the box like on the 02y? im guessing there is no inner seal on the input shaft (where the 02y pushrod would pass through with brass bush). i also need to do the crank main seal behind the clutch, what is the name/style of this so i can order it? rear crank? basically can anyone advise what to order, but not with vw part no's as i will be using gsf/vwspares as much as possible... thanks in advance for any help....
Offline danny_p
Re: 02y to 02a conversion
« Reply #1 on: 21 May 2011, 18:28 »
all 02a clutches will fit all 02a boxes, so vr6 clutch be fine.
the oil seal behind the flywheel is called a cranck end seal  thee are 2 ask for the fat one.
you also need a 02a flywheel
all the VW's have gone bar 1.
