Author Topic: new 16v timing chain  (Read 6974 times)
Re: new 16v timing chain
« Reply #20 on: 23 May 2011, 21:16 »
075 or 085 would be better on a 16v, the extra will help with starting etc.
Offline danny_p
« Reply #21 on: 24 May 2011, 00:06 »
i presume it not cranking over very well when hot.
when it's hot disconnect the king lead that goes to the dizzy and cranck it over,  if it spins over much better, your ignition timeing is out FACT
it's slightly over advanced   you need to loosten the nuts on the dissy and set it up with a timeing light.   the ignition timeing is diffrent to the timeing between the cranck and the cams and the inter cam timing,   it has it's own adjustment and is rather a lot more sensitive just fitting a new cam belt can throw it off
all the VW's have gone bar 1.
Offline mwep201081
« Reply #22 on: 24 May 2011, 01:11 »
Get a bigger battery......then set your ignition timing with a light. you'll think you have a different car
