Author Topic: new 16v timing chain  (Read 6975 times)
Offline bodga
  • F reg GTI 16v
Re: new 16v timing chain
« Reply #10 on: 23 May 2011, 16:31 »
Who knows but i can put hand on heart and say the cams and belt are set up correct on mine so it must be my dizzy out or starter tired.
weekend job me thinks, im on call but it should be quiet (bank holiday) :wink:
Offline Mew
« Reply #11 on: 23 May 2011, 18:54 »
it must be my dizzy out......
Otherwise known as ignition timing :wink:
Offline Sam
  • Sam I am
« Reply #12 on: 23 May 2011, 18:56 »
Me or Bodga? My point stands  :grin:
Offline mwep201081
« Reply #13 on: 23 May 2011, 19:01 »
After doing rings and head on my golf she doesnt like to start when warm. You can hear its all tight but should loosen up soon enough as I have only done 300 miles in her. I'm not too worried but, should I be?
What do you mean by tight? slow to crank when trying to start?
Offline Sam
  • Sam I am
« Reply #14 on: 23 May 2011, 19:04 »
Yer slow to crank and then just starts, as if you have worn your battery down trying to start and its on that last almost dead turn of the key  :embarassed:
Offline mwep201081
« Reply #15 on: 23 May 2011, 19:08 »
get a heavy duty battery and check your starting and charging circuit also.....
Offline Sam
  • Sam I am
« Reply #16 on: 23 May 2011, 19:13 »
But why would it be fine from cold but sh!te when hot? The battery is literally brand new but will get a volt meter on it and test across my alternator.
Offline Khare
  • The bear that khares
« Reply #17 on: 23 May 2011, 19:47 »
If anything it should be easier to start when hot. The starter motor on the 16v was real slow to crank over, hot or cold. Eventually it packed up, but I stuck a working one on and it cranks perfectly  :smiley:
Quote
smoother tickover, better response from low revs, and after 4000 revs  :grin: :grin: :grin:
Sounds like something I'd like  :cool:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #18 on: 23 May 2011, 20:03 »
Sam, that just sounds like your starter is shafted
Thom
Offline bodga
  • F reg GTI 16v
« Reply #19 on: 23 May 2011, 20:57 »
No sh!t :grin:
timing on mine is spot on peeps.  :grin:
Ive noticed though that the battery i have fitted is a type 065, (it came with the car when i brought it) but ECP quote a 075 to be fitted to a 16v, can anyone confirm this? what batteries are fitted to your valvers?
Ive aquired a battery off a ford transit (new one) but the terminals are the wrong way round :angry: Leads just not long enough to fit. good to test with jump leads thou :wink:
