Author Topic: Help  (Read 1248 times)
Offline StevoVR6
« on: 20 May 2011, 23:26 »
Hi,
I've recently bought a Vr6 just hit about 100-110miles in it and I've noticed the coolant has vanished, temp light keeps flicking on and off and there is a little hole to the right of the expansion tank under the cover is that meant to be there if it is what else could it be? help please, thanks
 :sad:  :sad:  :sad:
Offline cняis
Re: Help
« Reply #1 on: 21 May 2011, 22:04 »
The water wont just vanish. The coolant light flashing means you have no coolant in the expansion bottle.
It will be disappearing in one of the following ways:
- Boiling over (and dripping out of the side hole in the expansion bottle - you'd notice this!) This could be a serious overheating issue (i.e. caused by a stuck thermostat) or a pressure issue caused by a dodgy seal on the expansion bottle cap. Mine boiled over and the cap was missing the seal  :rolleyes: What does the temp gauge read?
- External leak. Either from one of the hoses/flanges or the heater matrix. Hose/flange leaks will be fairly easy to spot, do you get any drips on the floor when the car is warm? Heater matrix leaks either result in wet footwells or steam on the windscreen when the blower is switch on and put onto the "hot" position.
- Internal leaks. Check your oil filler cap and diptick for traces of mayo (water in oil). This is most likely caused by head gasket failure.
Offline GrandMstRamRod
Re: Help
« Reply #2 on: 21 May 2011, 23:43 »
well cnt be head failure steve! as when i checked your oil other day, it didn't have any mayo!
Offline StevoVR6
Re: Help
« Reply #3 on: 02 June 2011, 23:51 »
yeah we've checked for all signs of gasket, nothing to say it's that just going to buy another expansion tank and change thermo
Thanks
