Author Topic: Gearbox Compatibility  (Read 1041 times)
Offline catweazle
« on: 20 May 2011, 20:27 »
Hi all,
looking to replace the AUG gearbox on my 1.8gti as it has a really noisy bearing somewhere in it which only ceases with the clutch pedal down (replaced release bearing with no joy). I have toyed with the strip down option? But would like to think a wider selection of boxes would help in me being able to buy a good one. My question is am I able to fit another box with another code which is compatible. If so Is it a straight swap or are mods needed. Any thoughts would be appreciated.
« Last Edit: 20 May 2011, 20:35 by catweazle »
Offline Diamond Hell
  • Opinions я Us
Re: Gearbox Compatibility
« Reply #1 on: 21 May 2011, 21:38 »
Any 020 box will fit, but be aware the Golf 3 and 16v (IIRC) have a larger  (so stronger) input shaft. If you get one of these boxes make sure you get the right clutch to go with it.
Offline catweazle
« Reply #2 on: 21 May 2011, 22:22 »
Thanks for info. Would you advise to go for a mk3 box I understand that by then vw had gone back to the diff rivits that did not have problems.
