Author Topic: Golf GTi Mk2 Fuel Pipe HELP!!!  (Read 3122 times)
Offline golfgtimk28vman
« on: 20 May 2011, 17:50 »
I have a pretty bad fuel leak on my Golf GTi mk2. The fuel lines come from the tank and then disappear up into the car under the driver's seat sort of area, coming out under the air intake under the bonnet. The leak is coming from somewhere where the pipes disappear up into the car. So I need to replace the two pipes. The pipes are plastic. Where on earth can I find replacements for these pipes?! What size are these pipes, inside and outside diameter? The only ones I can find are rubber and seem much too big! Please help if anyone has had this problem or can offer some advice! Petrol is pricey enough already without it leaking away!
Offline theclash
Re: Golf GTi Mk2 Fuel Pipe HELP!!!
« Reply #1 on: 21 May 2011, 18:50 »
try gsf eurocarparts or vw spares all else fails take a sample of your pipe to somewhere who replace hydraulic pipes etc im sure they would be able to sort you out
Offline dadrathers
« Reply #2 on: 21 May 2011, 20:22 »
Try your VW dealer. For a digifant engine (and others I would guess ) this is what is listed 7x5 mm which again I would guess is the o/d and i/d.
Part number N 020 281 1 - comes in coils of 5 m???
« Reply #3 on: 21 May 2011, 21:38 »
Vw I would say is the best bet, needs to be high pressure rated.
