Author Topic: fan problem  (Read 1055 times)
Offline mark_gti
fan problem
« on: 19 May 2011, 23:46 »
hi for a few weeks now every time i start my car the fan seams to be turning on for a few mins even first thing on a morning
anyone had this issue
Re: fan problem
« Reply #1 on: 19 May 2011, 23:49 »
Faulty switch or control unit.
Offline mark_gti
Re: fan problem
« Reply #2 on: 20 May 2011, 00:35 »
ok were abouts are them if ya no
Offline dantheman6554
Re: fan problem
« Reply #3 on: 20 May 2011, 11:46 »
When you next go to your car in the morning, , BEFORE starting it, lift the bonnet , then start it up, and youll probably find the fans are stationary, the "fan" noise, is most probably the sceondary air pump which warms the cat up  (sounds like blowing, / vaccum cleaner)  then it cuts out?
The fan housing is secured with reviets which come apart allowing air to escape , causing the noise you here,  on here is a guide somewhere to taking it off and re rivetting it!
If it is actually your fans then this explanantion has been wasted, but hopefully not!  :cool:
Dan
Good Old Gt Tdi 115!
Offline mark_gti
Re: fan problem
« Reply #4 on: 20 May 2011, 22:38 »
thank you dantheman6554 its defo that i was baffled erlyer when it was making a noise and the fans wernt moving i had a feeling it was the air pump
Re: fan problem
« Reply #5 on: 21 May 2011, 18:05 »
No probs mate,  just gota get the B*tch off now,  their not too bad!  :smiley:
