Author Topic: GTi 16v Engine idle irregular  (Read 828 times)
Offline allycat
« on: 19 May 2011, 23:08 »
Hi
Can anyone offer any advise in this are, only at idle after a while the engine almost starts to develop an irregular idle like its missing.
Thinsg i have done:
new leads , spark plugs.
cambelt etc has been done at the same time, could it be the timing thats off.
Replaced the ECU and the 167 relay.
I will clean the stabilizer Valive tonight hopeflly that will resolve the issue but just in cas what else c i check. During the irregular idl the revs saty at a cinatnt 900rpn does not move.  Ihave replaced the airlines to the ecu aswell.
Thanks :smiley:
GTI 16V
Offline dragongreengolfgti
  • my golf gti mk3
Re: GTi 16v Engine idle irregular
« Reply #1 on: 19 May 2011, 23:18 »
mine sits at 900 rpm thats normal isn't it? dosn't miss a beat ever though apart from if you rev it the revs dont always drop straight away  :cry:
« Reply #2 on: 19 May 2011, 23:29 »
Could be an air leak.
Offline allycat
« Reply #3 on: 19 May 2011, 23:33 »
Hi
I think you right the revs stay at 900rpm at idle so makes it even more confusing for me because you can feel it throughthe seat of your pants when it misses. Will update once i figure out whats going on.
GTI 16V
Offline allycat
« Reply #4 on: 19 May 2011, 23:41 »
I have replaced the obvious visible airlines o the ecu and teh ones to the airbox, are there any other?
GTI 16V
