Author Topic: Starting to annoy me battery terminal disconnects it self :@  (Read 1222 times)
Offline mani12354
Right people this is one this which is pissing me off
my terminal for my battery keeps poping off for some bizarre reason n keeps restarting everthing i have clamped it down n stil ldoing it ??
Offline tweed
make sure it's at the bottom. I normally have to tap them down with a hammer.
Offline tweed
Show me a picture  :wink:
Offline golf newbie
You got the other problems sorted..?
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Bigger hammer required.
Offline mani12354
nope other problem not sorted it comes n goes like a sensor playing up :shocked:
wen i bang the battery terminal it all connects fine
Offline Adezmk3
If it is the clamp that's popping off shim it or file the slot/opening out a bit so when it clamps it is tighter (you could replace the clamp but shimming it is by far the simplest, cheapest and easiest thing to do), if its the actual terminal of the battery that is at fault I think your only option is to replace the battery.
You could try as a 1st to replace the clamp.
Offline Ninj
+1
30 sec fix tops, slacken the clamp, find a bit of anything-to-hand to take up any slack on the terminal where the clamp wont meet and you're sorted, there'll still be plenty of contact.  I had an Isuzu Trooper that spent most of its life with a bit of [insert whatever you like] jammed in the clamp and tightened.
If however the clamp is tight, it's possible the terminal itself is loose in the battery in which case, as above, new battery.
