Author Topic: 16v problem ?  (Read 2846 times)
Offline tattoomang60
  • smell the fear!!
16v problem ?
« on: 18 May 2011, 23:25 »
Hello all iv got a 16v golf mk2 1988. Iv got a problem with it firing on number 2 cly. Changed plugs leads dis cap rotor arm but still won't fire on num cly. Done a compreshion cheak and all are fine. There is feul getting thro. But num 2 cly is not burning the feul coz the plug is get black and smells off petrol. And also there is oil in the dist cap. Might this av somthing to do with it?
Anyone help please?
Thanks ian.
keep pushing the limits!!!
Offline mk2bal
Re: 16v problem ?
« Reply #1 on: 19 May 2011, 09:03 »
Search 'dizzy oil seal replacement'. Yes I reckon that's the first port of call for your problem...
Offline raferackstraw
Re: 16v problem ?
« Reply #2 on: 19 May 2011, 10:28 »
you wont get an original seal which iirc are 12.5mm inner diameter, but what i did was get a 12mm from a seal and bearing supplier and it works fine. there is a pin on the bottom of the dizzy shaft you need to knock out to take apart the dizzy. whats your location btw? there maybe someone nearby who could let you try theirs?
« Last Edit: 19 May 2011, 10:30 by raferackstraw »
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
  • smell the fear!!
Re: 16v problem ?
« Reply #3 on: 19 May 2011, 11:29 »
ello all thanks  for all your advice.
i live near ipswich suffolk GB.
thanks ian :laugh:
  • smell the fear!!
Re: 16v problem ?
« Reply #4 on: 19 May 2011, 12:26 »
ello again.
if changing that dont work what to try next???? :undecided:
cheers ian
Offline mk2bal
Re: 16v problem ?
« Reply #5 on: 19 May 2011, 17:10 »
Wait until you've sorted that, then if it persists come back. Should in theory be that though from the symptoms you have, and the parts you've replaced.
Offline Thom89
  • Looking for an "Icebreaker"
Re: 16v problem ?
« Reply #6 on: 19 May 2011, 18:37 »
Also fit a new set of the correct type plugs, if you haven't already done so...
Thom
Offline clipperjay
Re: 16v problem ?
« Reply #7 on: 19 May 2011, 20:08 »
Have you taken every plug out and earthed it to the block? That should confirm you have electrical issues for sure or not. Non?
  • smell the fear!!
Re: 16v problem ?
« Reply #8 on: 19 May 2011, 20:38 »
changed the plugs to the right ones to day gonna get a new bist tom fit that and see what happens.
thanks all for thehints and tip every one.
will let ya all know what the out come is.
cheers ian.
  • smell the fear!!
Re: 16v problem ?
« Reply #9 on: 20 May 2011, 19:56 »
ello all.
right the story so far.
fitted new dist unit new plugs leeds all is working fine all firing as it should press cheacked the pistons and all fine.
feul is fine.
but only running on 3clys still what hell can it be?????????????????????????? :cry:
HELP :angry:
cheers ian.
