Author Topic: merc sprinter intercooler pipes  (Read 1847 times)
Offline Dan_GTi8v
« on: 18 May 2011, 23:06 »
anyone know the size of the inlet/outlet on a merc sprinter intercooler? Cheers
Offline Bespoke Division
Re: merc sprinter intercooler pipes
« Reply #1 on: 18 May 2011, 23:36 »
Sorry don't know the answer to that  :sad: but by any chance are ousing it for a 1.8t conversion???
Your Vision Is Our Mission
Offline Dan_GTi8v
« Reply #2 on: 19 May 2011, 13:36 »
yes I am :) conversion is already done using a universal fmic but its 65mm thick, so it touches the slam panel and cant be put where I want it which causes it to rub on the bumper and forces the splitter to sag, which is causing me to hit the floor in my works carpark :(
After the sprinter cooler as its only 30-35mm thick. Also need to measure up as the inlet/outlet will be pointing towards the engine instead of out the side like on the fmic
« Reply #3 on: 19 May 2011, 13:52 »
Ok cool
I am in the middle of doing a 1.8t conversion & I am going to use a intercooler off a a4 2.0tdi 2009, so far it looks like it will fit :cool:
Offline Dan_GTi8v
« Reply #4 on: 19 May 2011, 16:06 »
I may check this one out as well, 65mm is only slightly too thick if I remember rightly but the merc sprinter is the only cooler I know thats thinner. Just not sure about the pipe fitment may have to do some investigating tonight :P
Offline tweed
« Reply #5 on: 19 May 2011, 17:52 »
My mate works at pro alloy check them out. Should make anything you want. also pace products is good. Have a friend work there too.
Cheap parts for me when I need them  :grin:
Offline Dan_GTi8v
« Reply #6 on: 19 May 2011, 18:39 »
Thinking I may go for the VW LT van intercooler now, same as the Sprinter but comes in black, will go nicely with the theme of my car :)
