Author Topic: rear valance mk4  (Read 3977 times)
Offline brown29
rear valance mk4
« on: 18 May 2011, 20:49 »
Hello, am after a rear valance for a 1.8 GTI mk4 with cut out so I can put a mill teck twin exhaust through it.
Can any one point me in the right direction?
Thank you  :smiley:
MK4 1.8T GTI
Offline richw911
Re: rear valance mk4
« Reply #1 on: 18 May 2011, 20:51 »
You need a 4-Motion rear valance part number 1J6807521C from your VW dealer
Around £45  :smiley:
Offline damien010685
« Reply #2 on: 18 May 2011, 21:22 »
i have a black used 4motion rear valance you can have for £10 plus postage which will be about £8 its a genuine part clips all intact cant send until im back from offshore though will be within 2 weeks
Offline brown29
« Reply #3 on: 18 May 2011, 22:01 »
Will this be ok fitting the mk 4 gti? also will i be able to fit a twin exhaust through it?
Also if i get it sprayed will it be ok? heard some rear valances can't be sprayed.
thanks
MK4 1.8T GTI
Offline brown29
« Reply #4 on: 18 May 2011, 22:23 »
does any know if you can clour code 4-Motion rear valance part number 1J6807521C ?
I have heard you can't spray some valances because the paint will come off?
MK4 1.8T GTI
Offline Gareth F
« Reply #5 on: 18 May 2011, 22:44 »
As long as you prep them properly they will be ok, if someones used back to black or bumper shine crap then you need to make sure you get it all off before painting.
No SmOkE nO pOkE....
« Reply #6 on: 18 May 2011, 22:56 »
yes you can use twin exhaust as the 4motion comes standard twin pipe and yes you can paint it but as gareth says need to clean and prep first
Offline brown29
« Reply #7 on: 18 May 2011, 23:06 »
damien010685 do you want to send us a private message then when you back offshore and I will buy that from you.
£20 all in - Is that ok?
« Last Edit: 18 May 2011, 23:08 by brown29 »
MK4 1.8T GTI
Offline daz veedub
  • Operation 1.8t bolf
« Reply #8 on: 18 May 2011, 23:26 »
check mowlambs project thread on spraying valences/splitter  :smiley:
http://www.golfgtiforum.co.uk/index.php?topic=144406.0
« Reply #9 on: 18 May 2011, 23:29 »
yip il do that mate il message you when i get back :D
