Author Topic: stainless steel manifold  (Read 1570 times)
Offline dubslug
« on: 18 May 2011, 18:42 »
If stainless steel manifold has cracked on the pipe where the four pipes join into one, can this be welded while manifolds in situ on the car, there really isnt much clearance room as its cracked on the side of exhaust nearest the bulk head  :cry:
cheers
Rik
1992 pearl grey 8v
Offline stevelfc
Re: stainless steel manifold
« Reply #1 on: 18 May 2011, 19:42 »
best thing do is take it off so you can get a good weld on it so it will be neat and covered all the area
Offline dubslug
« Reply #2 on: 18 May 2011, 20:15 »
nuts was hoping not to have to do that. cheers for advice, is a rewelded manifold gonna last though???
or would a new one be best???
1992 pearl grey 8v
Offline stevelfc
« Reply #3 on: 18 May 2011, 20:25 »
all depends on how good the weld is and how good the guy is at welding . I had a motor x bike stainless steal exhaust welded when it spilt and it lasted the 12 months i owend the bike and sold it on to a m8 and he had no trouble so its up to you m8 also depends on how much to get it welded and how much it would cost for a new one  :smiley:
Offline dubslug
« Reply #4 on: 18 May 2011, 21:01 »
from what ive seen there abt 180 upwards....
also does anyone know if miltek slightly overbore there down pipe as my mid section and down pipe had to be welded together as they were same bore size
1992 pearl grey 8v
« Reply #5 on: 18 May 2011, 23:27 »
Better to take it off and weld it, may not last however.
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 22 May 2011, 11:03 »
Why wouldn't it last? If it's welded with the right material by a competent welder, it should be stronger than when it was built originally.
 :rolleyes:
