Author Topic: coolant detergent / flush  (Read 2800 times)
Offline kniterider
  • had most, sold most and often buy more!
« on: 17 May 2011, 22:19 »
is there any form of coolant flush/deterent i can run to remove the traces of oil from the system from when my head gasket popped last week?? have flushed with water a few times but it dosnt seem to shift the oily residue from pipes etc, all is running fine since i rebuilt it but all the smeg from the system is making its way to the top (expansion bottle) and would really like to rid this so i can check all is running as it should be!! , oil has been flushed and is fine, hasnt used a drop and is clean, so just want to get this cleaned 100% so i can monitor it to make sure nothing is mixing any more?
cheers for any help
Gaz
Offline kniterider
Re: coolant detergent / flush
« Reply #2 on: 17 May 2011, 22:28 »
cheers for that, think ill try a bottle and see if it shifts all the remaining gunk......
 :smiley:
Offline Agreeable Slick
  • Unit
« Reply #3 on: 17 May 2011, 22:44 »
Just be aware that any bio agent will begin to degrade your rubber hoses, o rings, gaskets etc as they are all oil based as well.
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 17 May 2011, 22:48 »
Use a mug of non bio Persil, in the system, and run up for 15 to 20 mins, flush out thoroughly, and fill with 50/50 water antifreeze mix.
Thom
Offline kniterider
« Reply #5 on: 18 May 2011, 08:58 »
hhmm food for thought, its a 20 year old car i dont want all perishable bits to go faster than they are already so maybe the flush isnt a good idea?? but then the thought of putting persil in the car seems wrong, might make it smell nice though :)
Offline mk2bal
« Reply #6 on: 18 May 2011, 11:21 »
Calgon works well and is designed to work with rubber seals etc etc
Offline molegti
« Reply #7 on: 18 May 2011, 12:35 »
I've heard of a dishwasher tablet being used too.
Offline clipperjay
« Reply #8 on: 18 May 2011, 15:33 »
Just stick in two part Holts rad cleaner Gaz, then stick a hose on the end of the pipe and flush it all out
For the sake of £8 quid I'm sure there is more harmful products in detergents than stuff thats been tried and tested. I know they stick alot of sodium in detergents which is not good for the car LOL.
Offline mk2bal
« Reply #9 on: 18 May 2011, 20:59 »
Too much salt can lead to a heart attack
