Author Topic: tdi  (Read 1408 times)
Offline polo6n222
tdi
« on: 17 May 2011, 19:05 »
can the mk3 1.9 tdi 95hp be remaped if so what sort of hp gain would it reach thinking about one as a daily
Re: tdi
« Reply #1 on: 17 May 2011, 19:06 »
Don't believe it can be remapped from what I have read.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: tdi
« Reply #2 on: 17 May 2011, 21:06 »
Oh I thought these could or is it just the 110bhp (and upwards) derv engines that can?   :undecided:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: tdi
« Reply #3 on: 17 May 2011, 21:39 »
I think they can, the ECU has a map on the chip, so a different chip can be fitted, it cant be flashed though as far as i know, so its a solder in jobby.
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Jack3559
Re: tdi
« Reply #4 on: 18 May 2011, 00:00 »
I'm sure it can be remapped...
Re: tdi
« Reply #5 on: 18 May 2011, 09:00 »
I believe the problem is that the chip is soldered, I was only going past threads.
Offline Len
Re: tdi
« Reply #6 on: 18 May 2011, 09:03 »
Ask Rtech they are THE experts!
www.sas.org.uk
www.the-ace.org.uk
Offline madmanmart
Re: tdi
« Reply #7 on: 18 May 2011, 12:49 »
Yes they can but the chip has to be de-soldered then a new one flashed and refitted.
Nothing power wise can be done through the ECU port.
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
Re: tdi
« Reply #8 on: 18 May 2011, 13:29 »
one small problem with the logic you have just said nearly all tdis that i know of that are in the mk3s all run the same ecu which controsl a mechanical pump which has an electronic head put o and the ecu that they use is not one that is chippable unless you solder an eprom in then get that flash mapped, only problem with this is it has minimal mapping possiblities and no one i can find will do it in the uk and trust me iv looked the only place is america, i know all this as im doing my uni project on it and thats why iv gone for a hybrid mechanical tdi conversion with a 12mm head in allowing over 250 horse
 :undecided:
Offline polo6n222
Re: tdi
« Reply #9 on: 18 May 2011, 14:35 »
Quote
We can chip tune the mk3 TDI ecus, power gains will be around 25bhp30lbft. The ECU will need a new set of chips for the software to be loaded on to.
The price for the chips and remap software will be £200 fitted.
Nick
