Author Topic: Non-GTI fuel pump/ fueling  (Read 1217 times)
Offline wurth
« on: 17 May 2011, 18:58 »
Right, my ryder came with a Facet posi flow fuel pump, mounted to the bulkhead, after this is a sytec pressure reg, then it led to the standard pressure reg/overflo pot, then to the carb/return to tank.
Soo, first questions is, the fuel pump knocks sometimes, especially if the tanks funning low, spoke to the facet specialst, he said the model I had needs to me mounted next to the pump, so which alternative fuel pump have people used mounted to the bulkhead? Facet soild sate ?
Second  questions is is it nessasary for the OE regulator/ fuel pot to be there as i already have a pressure reg and high flow pump? or can i just set my pressure, and delete the return line ?
No smart coments "whats wrong with the mechanical one" etc etc.
Thankie
