Author Topic: which flywheel to use  (Read 3345 times)
Offline rossbarry1
« on: 17 May 2011, 17:42 »
im thinking of lightening my flywheel on a 8v gti, can i just bolt a g60 one on or one from another model which is lighter or do i need to get the original lightened. Cheers guys
Offline Simeon
Re: which flywheel to use
« Reply #1 on: 19 May 2011, 14:09 »
Can't use a g60 one, just need a 210mm 020 one off another gti 8v or 16v
Offline rossbarry1
« Reply #2 on: 19 May 2011, 15:53 »
wont that be already what i have though
Offline mk2bal
« Reply #3 on: 19 May 2011, 17:08 »
Think 16v has 28splines on g/box input shaft, and 8v has 24 (smaller). So match it to whatever box your using,they all fit the crank the same...
Offline rossbarry1
« Reply #4 on: 19 May 2011, 17:56 »
yea but i want a lighter one
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #5 on: 19 May 2011, 18:32 »
then send yours away to be lightened and balanced  :smiley:
Offline rossbarry1
« Reply #6 on: 19 May 2011, 19:42 »
to whom, i have no idea. thanks
Offline Simeon
« Reply #7 on: 19 May 2011, 19:54 »
Thats the friction disc, the gti flywheels are all the same.
Yes, but unless you want your car off the road whilst it's being done then you need to get another one to send away.
To be blatently honest mate you shouldn't waste your time or money as it's going to make negligable difference to an 8v gti. Save your pennies for an engine conversion if you want to go quicker.
If you really want to do it then look up a local engineering shop or if you can't find anyone then try hotgolf on clubgti
Offline rossbarry1
« Reply #8 on: 19 May 2011, 20:16 »
okies, its not a std 8v  :wink:
Offline Simeon
« Reply #9 on: 19 May 2011, 20:22 »
Unless it's FI is still not worth it :tongue:
