Author Topic: Can someone explain this please mk3 gti 2.0 16v  (Read 1957 times)
Offline mani12354
Click the picture for the video
 :cry:
Offline mani12354
Offline sharki786
  • GOT BOOST??
Re: Can someone explain this please mk3 gti 2.0 16v
« Reply #2 on: 17 May 2011, 10:17 »
had same prob on mine ages ago. turned out to be the o2 sensor (lambda sensor) get vag com on to it, that will give you more details
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline mani12354
« Reply #3 on: 17 May 2011, 10:19 »
where is the lambda sensor and isit easy to change?
Offline golf newbie
« Reply #4 on: 17 May 2011, 10:24 »
Lambda sensor is probe attached to the front pipe.
Worth disconnecting the lambda sensor see if it runs better.
The connector is above the rear engine mount.
Offline mani12354
« Reply #5 on: 17 May 2011, 10:25 »
where can buy one from and how much isit?  :shocked:
Offline golf newbie
« Reply #6 on: 17 May 2011, 10:27 »
They about 50-70 quid from gsf etc.
Try disconnecting the sensor first if it runs better without the sensor then you know thats the problem.
Offline mani12354
« Reply #7 on: 17 May 2011, 10:32 »
 :shocked: expensive  umm so i got get under the car  :grin: lol thanks for that  :rolleyes:
Offline golf newbie
« Reply #8 on: 17 May 2011, 10:38 »
You dont have to get under car.
The connector to lambda sensor is on the left hand side of engine bay should be near the master cylinder its a oblong connector just disconnect that and run engine.
Offline mani12354
« Reply #9 on: 17 May 2011, 10:50 »
awsome ill give it a go  :grin:
