Author Topic: MK3 1.8 Running issues  (Read 2855 times)
Offline D Squared
« on: 17 May 2011, 07:12 »
Help... my mate has a 1.8 mk3 Golf i think it is ABS engine code, 'M' reg...
It starts up and run ok from cold, but as soon as it starts to get warm it starts to run very rough.. its almost like as soon as the cold start enrichment comes off due to increased coolant temp, it then starts running rough...
Is there any common issues like this that someone can point us in the right direction..? perhaps lambda sensor, or wiring?, single point injection head?? does this problem ring any bells with anyone...??
Any help appreciated.
DD
MK3-MK5- Now MK7 GTi
Re: MK3 1.8 Running issues
« Reply #1 on: 17 May 2011, 08:55 »
Might be worth replacing the temp sender as a 1st step.
Offline D Squared
« Reply #2 on: 17 May 2011, 18:42 »
think he has changed 1 temp sender, on this model does the same sensor control the coolant gauge? because i know he has changed that sensor...
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #3 on: 23 May 2011, 16:49 »
Its the same sensor (4pin blue)
This being single point has the rubber mount under the injection unit, ill bet if you cant find anything obvious causing this, the rubber will be split/warped.  they are about £25 and takes half hour to swap, very simple.   Caused me a headache a few years ago, turned out its quite common
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline D Squared
« Reply #4 on: 25 May 2011, 22:09 »
So does the rubber mount on the underside used to seal it? and therfore you had an air leak?
I'm fairly sure the injection unit has been off, and i'd like to think they would of spotted that if anything was untoward...
Offline Rmachines
« Reply #5 on: 26 May 2011, 17:02 »
I had my injection unit off 4 times before i decided the rubber seal was perfect and its nothing to do with it... guess what...  it wasnt!   I couldnt see anything wrong with mine what so ever, but i replaced it, and sure enough it worked, although you might notice the hole where the fuel/air goes through gets crinkly/split.   Its worth a go.   It seals its self against the intake manifold and against the injection unit,  also provides a softer ride for the injector, allows it to move a bit.
Offline LowlifeDubber
« Reply #6 on: 26 May 2011, 18:53 »
It's a common problem on ABS engines mate,ive had it myself where it looks fine but it is perished.Go to GSF they do them for £23.Dont forget the large o-ring that goes underneath the gasket.
Here is the part you need.
Offline D Squared
« Reply #7 on: 26 May 2011, 21:02 »
cheers guys i'll look into it..
DD
