Author Topic: GTi 16V Gearbox Diagram  (Read 770 times)
Offline allycat
« on: 16 May 2011, 23:18 »
Hi All
I recently found that my car is leaking oil between the gearbox and the Engine. Does anyone have a diagram so i can allocate the asssociated parts. Will take he car off the road and do it my self with the help of a friend. Can you recommend a VW spare onlinestore?
Thanks :smiley:
« Last Edit: 16 May 2011, 23:36 by allycat »
GTI 16V
Offline neil1780
V6 4MOTION
Offline allycat
Re: GTi 16V Gearbox Diagram
« Reply #2 on: 17 May 2011, 01:57 »
Great thanks, most helpful.
GTI 16V
« Reply #3 on: 17 May 2011, 09:04 »
Is it gear oil or engine oil that is leaking.
Offline Dan_GTi8v
« Reply #4 on: 17 May 2011, 13:47 »
between the gearbox and engine is dry as thats the clucth and flywheel, the gearbox oil will only be at the bottom where the gears are?
Check your oil pressure sensor on the side of the block it should have a rubber boot over it that is probably full of oil :)
