Author Topic: Changing crank sensor  (Read 1974 times)
Offline nightroamer
  • Mk3 16v
« on: 16 May 2011, 17:57 »
Hi guys,
I'm trying to change my crank sensor.
I have the engine supported on a jack, and have managed to do the front starter motor / engine bracket bolt.
Any idea what size the bolt through the engine mount is? Seems like a 16 but thought this maybe odd!? Asking as I will need to buy one that size if it is so.
Also what other bolts to I undo?eeek
Anyone have a photo?
Thanks
Offline Khare
  • The bear that khares
Re: Changing crank sensor
« Reply #1 on: 16 May 2011, 19:16 »
You've removed the front engine mount correct? There's only 1 bolt holding the crank sensor on, it's a 6mm allen bolt I think.
Offline nightroamer
  • Mk3 16v
« Reply #2 on: 16 May 2011, 19:17 »
No I was asking about the mount.
Seems an odd size
Offline Khare
« Reply #3 on: 16 May 2011, 19:19 »
16mm sounds about right  :smiley:
Offline nightroamer
  • Mk3 16v
« Reply #4 on: 16 May 2011, 19:22 »
Cool, will have to buy one,
Never needed a 16mm before lol.
Ta
Offline tweed
« Reply #5 on: 16 May 2011, 20:09 »
couldn't you just undo the bottom with allen key?
Offline nightroamer
  • Mk3 16v
« Reply #6 on: 16 May 2011, 21:20 »
Are they connected through? I freed off the Allen bolt but it all seem to stay put
Offline nightroamer
  • Mk3 16v
« Reply #7 on: 17 May 2011, 18:18 »
Anyone had any experience of removing just the bottom Allen bolt? Will this work?
Offline golf newbie
« Reply #8 on: 17 May 2011, 18:48 »
I removed the front sub frame when i replaced the front mount.
Think its called a front sub frame its just held on by four bolts.
Offline nightroamer
  • Mk3 16v
« Reply #9 on: 17 May 2011, 18:52 »
Is it straight forward, or is he engine mounted on it, in which case I can't remove it really
