Author Topic: SOMEONE HAS TO HELP ME  (Read 6926 times)
Offline Komenda
Re: SOMEONE HAS TO HELP ME
« Reply #10 on: 20 May 2011, 20:13 »
Water damage and corrosion on the contact's causes this due to the wire/contact's are copper.
Agree with that. Will be a pain in the arse but may be worth pulling all the fuses, drying out the box and wire brushing the contacts.
Might even be worth getting a new box from the breakers, as a last resort.
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #11 on: 20 May 2011, 21:13 »
Don't want to sound like Wayne but +1 - it's corrosion  :sick:
Offline _Adam_
« Reply #12 on: 20 May 2011, 21:14 »
i havent cleaned it yet, was only a quick look as didnt have a lot of time. will do it tomorrow morning i think.
could this be causing the cut outs? wouldn't more of the electrics be fruity?
Offline Komenda
« Reply #13 on: 20 May 2011, 21:17 »
From your original post, it sounds like enough already is.
Offline _Adam_
« Reply #14 on: 21 May 2011, 11:01 »
took the fusebox completely apart, and all 3 sections had blue sh!te / liquid on them. got out the cotton buds, towel, hair dryer and wire brush and cleaned every single terminal.
took it for a drive (11 miles) with both calm, and jolly driving, testing bumps, g-force, etc. i didnt have a single hitch, i need to drive a bit further to be sure but it's looking on the hopeful side  :smiley:
hang fire on tomorrow Rhyso, i dont want to waste your time  :wink:
Offline Egbutt Wash
« Reply #15 on: 21 May 2011, 12:35 »
What you need to do now is determine why the water was on top of the fuse box when you looked at it.  It will only happen again if you can't stop water dripping onto and seeping into your fuse box.
Currently digging a bunker.
Offline The Doc
« Reply #16 on: 21 May 2011, 12:38 »
Good luck Adam  :wink:
Offline Komenda
« Reply #17 on: 21 May 2011, 14:50 »
Glad things are moving in the right direction. Next port of call, check the drains are not blocked.
Offline _Adam_
« Reply #18 on: 24 May 2011, 10:19 »
ok still no cut outs. i drove into work today for the first time since this happened, and it didnt cut out
BUT
it did have one 'hiccup' where the power dropped, and the glow plug light showed for 1 second.
a little worried still  :sad:
Offline S4twiggy
« Reply #19 on: 24 May 2011, 19:25 »
get rhys to run some logs on it and let him work his magic looking for things in there that we cant see. something is definately wrong mate so better to get vag-com on it and see whats up than anything going badly wrong on the car
Audi S4(B5) BBS CH's, Eibach pro street coilovers, B5 RS4 brakes(360mm), MRC remap 320hp 370lb ft. Fully Certified Detailer
