Author Topic: Temperature gauge  (Read 1763 times)
Offline mash
Temperature gauge
« on: 29 March 2005, 11:24 »
The temp gauge keeps reading zero but then intermittently would start reading the correct temperature and then goes back to zero.
Any ideas?
cheers
Offline nasher1001
Re: Temperature gauge
« Reply #1 on: 29 March 2005, 14:05 »
i have that same problem what exactuly is your car?
mine is gti tdi 115 diesel
Offline mash
« Reply #2 on: 29 March 2005, 15:55 »
Its a GTi 1.8T on a 2001 plate.
Offline Flipmode
« Reply #3 on: 29 March 2005, 18:22 »
this has happened once to me and was about to tell the dealership as was due in in any case for lubrication service, bu then the gauge just started working again by itself and not been a problem since. i think if u look in the haynes manual it tells u where the temp sensor is, u can check some connections yourself, but the actual sensor itself needs to be checked by a specialist with the correct tools me thinks.
Offline vaughn
  • now team wagon, and team grumpy trainee
« Reply #4 on: 29 March 2005, 18:58 »
just put my mk4 on vagcom with the same problem and it was the temp sender
57 plate black 5dr ed30, 1969 bay window devon camper. thats all for now folks, hopefully picking up a wagon tomoz
