Author Topic: Forge 007p Servicing  (Read 866 times)
Offline master_oogwai
« on: 16 May 2011, 11:34 »
I was doing some googling about the 007p and found a post about 'servicing' the 007p. I have had the 007p on the car for about three years and it has never been serviced  :huh:
Is this necessary or can I just leave it?
How can you tell if you have a buggered 007p? is it always suppose to be quiet even when you boot it, as when I give it full throttle in 3rd gear on mine, it gives a high pitch (sort of like an old kettle boiling) kind of sound.
Thanks for any help and do apologise if this seems to be a numpty question.
Offline daz veedub
  • Operation 1.8t bolf
Re: Forge 007p Servicing
« Reply #1 on: 16 May 2011, 12:09 »
if u take the vaccuum hose of top of dv and blow in2 it if it moves i fink its foooked
if ur after the tssssssh noise adding a induction kit will get this
and the whistling noise will be ur turbo spooling up
