Author Topic: 220 miles with full tank  (Read 3362 times)
Offline sychosis
Re: 220 miles with full tank
« Reply #20 on: 18 May 2011, 09:12 »
I managed to get 150 miles outs of £40  :cry:
Offline mhoney
« Reply #21 on: 21 May 2011, 19:01 »
Hi i get 300 miles to a full tank around town and on motorway 450 mile to a tank
I had my coolant temperature sensor fail not very long ago and was only getting 150 to a tank :sad:
matt
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #22 on: 21 May 2011, 19:13 »
What you have to remember is its the price of petrol going up making the MPG decline £1.38 a L at my nearest garage and when your low you dont have much choice as that red line alway seems to sneak up on me.
It's not it's making the £ per mile go up.
You not putting more fuel in, it's just more expensive and the OP said per tank full not per £50 quid note  :wink:
OP you need to get your exhaust fixed then get a fault code machine on your motor to check for faults sensors etc once you've had the exhaust repaired.
Once any faults have been sorted try short shifting and observe speed limits when driving - or break 'em and get it in 5th  :grin:
Offline Adam
« Reply #23 on: 21 May 2011, 22:18 »
Try surviving with a car that does 250miles to £114 :cry: :cry:
Down Hill From Here.
Offline Jasikasisback
« Reply #24 on: 27 May 2011, 03:10 »
Ummm maybe air/fuel ratio the cause? Cracked hose? Plus the maf sensor may be touchy. Other leaks? Maybe someone is siphoning fuel?
Try this out. Fill up car. Go for drive on motorway and go at 50-60mph constantly for say 60miles.
Fill up car again. How much fuel did you use? I'd say up to 7-8 litres is acceptable. Over 9 then you are running rich. Over ten then you have the swiss cheese effect.
Your fuel economy is really bad. Unless you drive at 100mph everywhere and change gears only when it redlines.
Gavv8
« Reply #25 on: 27 May 2011, 06:15 »
Thats got to be a chelsea tractor, i keep seeing cheap Range Rovers and the 'want one' factor is way up there..
Offline freezaburn
« Reply #26 on: 27 May 2011, 07:45 »
220?!  You should be getting at least 300. Sounds like you should also have your CO2 level checked on a VAG155x.
Offline Khare
  • The bear that khares
« Reply #27 on: 27 May 2011, 11:25 »
He's got a 350Z. Sounds about right tbh  :laugh:
« Reply #28 on: 27 May 2011, 11:35 »
Nope he did have a 350z  :lipsrsealed:
Offline Guy
« Reply #29 on: 27 May 2011, 11:46 »
i was going to say about the MPG decline comment when I read the thread.. but you said it for me Doc  :smiley:
