Author Topic: electric window switches?  (Read 3452 times)
Offline aaron1980
« on: 15 May 2011, 11:55 »
Hi my car is a small bumper car that has the electric window switches in the dash as opposed to the center consol the problem is the switches dont fit well at all (some times they just push through the dash) im starting to think they are the wrong switches? as all the pics i can find of electric window switches in mk2,s is ones where they are in the consol. has anyone got any pics of there window switches so that i can compare them with mine. thanks. this is the mess i have
Offline molegti
Re: electric window switches?
« Reply #1 on: 15 May 2011, 13:00 »
I'd hazard a guess they have been retro fit. I've never seen them on the dash.
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 15 May 2011, 14:24 »
there definitely dont look right they aren't even straight..
Offline aaron1980
« Reply #3 on: 15 May 2011, 14:54 »
they are not straight because of the size of the holes. i think molegti is wright and they must of been fitted at a later date and as the center consol only has a storage hole above the ash tray someone has stuck the switches in the dash. so now i just need to sort out the best way to tidy them up with out changing the consol. thanks all :smiley:
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #4 on: 15 May 2011, 15:12 »
Correct fitment for that type of switch...
What's in your center console?
Thom
« Last Edit: 15 May 2011, 15:15 by thom89 »
Offline aaron1980
« Reply #5 on: 15 May 2011, 16:13 »
is there more than one type of switch then?
This is my center console
Offline Thom89
« Reply #6 on: 15 May 2011, 16:43 »
What year is your car? that looks like a very early item, the correct console should be easy and cheap to get hold of, and just drop straight in, if OE looms have been used, then they should reach the correct position on the new console...
Thom
Offline aaron1980
« Reply #7 on: 15 May 2011, 16:56 »
its a 1988 16v.
what should be where my switches are then?
Offline Thom89
« Reply #8 on: 15 May 2011, 17:18 »
Blanks!
Would have thought you car would have had EW's from Factory, maybe the first owner wanted manuel winders, or someone has nabbed them!  :rolleyes:
Thom
Offline aaron1980
« Reply #9 on: 15 May 2011, 17:55 »
mine also has these blanks on the door cards? do they all have this is dose this point to it having manual winders at some point? sorry for all the questions  :smiley:
