Author Topic: gti starter  (Read 1427 times)
Offline jambo_the_great
gti starter
« on: 14 May 2011, 22:26 »
Just bought a gti and the only way to start it is by bumpstarting i have been told its a problem with the starter but am not sure so any help would be great
Offline dazzawest1987
Re: gti starter
« Reply #1 on: 14 May 2011, 22:38 »
Start by checking your battery voltage and then lives and earth to your starter, does it do anything when you turn the key?
Offline Screech16v
  • MK3 20vt AGU
Re: gti starter
« Reply #2 on: 14 May 2011, 23:52 »
Ignition switch is very common to fail also,very cheap to replace and pretty simple to fit :smiley:
Re: gti starter
« Reply #3 on: 15 May 2011, 00:00 »
Check all wiring etc, ignition switch is a very common failure.
Re: gti starter
« Reply #4 on: 15 May 2011, 00:01 »
All the lights come on like the handbrake and oil. Was told that the ignition switch had been replaced a few months ago
Offline Seanl
Re: gti starter
« Reply #5 on: 15 May 2011, 07:08 »
As Dazzawest said, check voltage at the starter motor. Its the only way you can tell if your problem lies with the motor itself, or if you have an issue further back.  :wink:
Re: gti starter
« Reply #6 on: 15 May 2011, 07:43 »
does it click, when you crank?
Re: gti starter
« Reply #7 on: 15 May 2011, 11:27 »
i dont think it clicks not that iv heard anyway. There is a droning sort of noise though
Re: gti starter
« Reply #8 on: 15 May 2011, 18:04 »
Droning noise from the engine bay when cranking? Could be that the solenoid failed in your starter and it's not firing the gear out,  :undecided: wouldn't of said that would be a droning noise though
Offline Seanl
Re: gti starter
« Reply #9 on: 16 May 2011, 21:16 »
Droning noise is probs just your fuel pump priming. I take it that happens at the second position on the ignition. Where have you got with it so far? Like I said before, I changed mine on friday and the old one was spinning (you could hear the motor whine, but had a duff solenoid so the gear wasnt firing out to the flywheel. If you cant hear anything, then checking voltage is your only option.
